ISAless Help - Page 10 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-13-2017, 07:32 AM   #181
ic033
My Ride: 330ci
Thanks for the input!
For additional info, engine is on stock maf right now.
We've looked through the idle data for NA and FI and on idle:
NA Maf 14kg/h
FI Maf 50kg/h
NA Load ±100
NA Load ±300
I've put a 0.5kohm resistor and will look at Load and Maf indications later in the day
ic033 is offline   Reply With Quote
Old 03-17-2017, 02:59 AM   #182
ic033
My Ride: 330ci
Take off!
Old 03-21-2017, 05:52 AM   #183
LKMT
My Ride: N/A
Originally Posted by ic033 View Post
Take off!
Nice to see that you got it rolling What did you change to make it work?
LKMT is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-31-2017, 09:30 PM   #184
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
OK,
My isa has failed and I have just setup the ISAless tune. I have MS42.
Is the new throttle map to stop the engine from stalling when engine braking/transition to a stop?
I am having that problem but I have not changed the throttle map yet.
What throttle position do others have for a steady idle? Mine is around 3.5% (M52TU25B)
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 04-01-2017, 01:48 AM   #185
LKMT
My Ride: N/A
Originally Posted by Blu302 View Post
OK,
Yes the throttle map will have to be adjusted on MS43 atleast. The ecu pulls values from the throttle map on how much to open the throttle for a given isa duty cycle.
But if you modify the ip_pvs_isa_isapwm__isapwm table instead you should be able to use whatever throttle map you want. I explained the tables function here Post 127
My M54B30 idles around 2.9~3.0
My latest ISALess values can be found here Post 159
Old 04-01-2017, 05:45 AM   #186
Blu302
Year: 98
Model: E46
I have adjusted the throttle map and it has made no difference for me(MS42) just tried it today.
After reading through your posts, ip_isapwm_pvs__pvs__n is what I changed before to get the throttle map to behave with a close to linear throttle curve and give better rpm drop..
I have altered the PID maps and ip_isapwm__tco for a smooth idle.
Old 04-01-2017, 06:53 AM   #187
LKMT
My Ride: N/A
When I experimentet on my car I found that lowering the ip_isapwm_pvs__pvs__n table in the idlespeed region would have a negative effect on the idle logic if the ISA valve was removed.
My tips would be to start over with everything ISA related set back to stock and then applying the ISALess changes to see if that makes a difference.
But I also believe there is something more that needs to be changed before the current ISALess method is working correctly but I haven't had the time to research it.
Old 04-01-2017, 11:17 AM   #188
cwarel
My Ride: 330ci coupe
I had same issue on ms43 when car would stall in between the transition to a stop. It just happened to me once I fixed my vacuum leak))) So i guess unplanned vacuum leak will fix it ( or more air through throttle)
cwarel is offline   Reply With Quote
Old 04-12-2017, 02:18 AM   #189
daniel_f.
My Ride: 330iC
Anyone willing to test ISAoff with automatic gearbox? We made some nice progress and think we found the problem. Car should be in stock condition, not boosted.
No further development on MS4x from me.
Old 04-19-2017, 12:42 AM   #190
Michel20
My Ride: 528iA LPG
Here i have a automatic, but its a 528iA. I'm from near Karlsruhe, where are you Daniel?
Is there a plate for isa/disa off on the m54b30 manifold?
Michel20 is offline   Reply With Quote
Old 04-19-2017, 02:09 AM   #191
daniel_f.
My Ride: 330iC
Is there a plate for isa/disa off on the m52b30 manifold?
Cologne
I´m not shure if its working on M52tuB engines.
Old 04-28-2017, 10:42 AM   #192
fipse
My Ride: e46 330ci
HI,
I'm wondering that nobody asked this before but if i only remove the electrical connection to the ISA will it stay shut?
Can somebody verify that with a removed valve pls
thx
-f
fipse is offline   Reply With Quote
Old 04-28-2017, 01:58 PM   #193
daniel_f.
My Ride: 330iC
Originally Posted by fipse View Post
HI,
thx
-f
Nope, either force it to be closed by changing maps, seal the isa with silicone or hot glue or remove the whole isa and plug it.
Old 04-29-2017, 03:55 PM   #194
xi46
My Ride: 2002 330xi ZPP/SP/CW
Is it easy to do by changing maps along with the current ISAless tune on the wiki? I haven't seen any info on that.
xi46 is offline   Reply With Quote
Old 04-30-2017, 01:08 AM   #195
daniel_f.
My Ride: 330iC
No one tested it, so i would definately recommend removung it, thats whats definately working.
Old 05-02-2017, 11:05 AM   #196
cwarel
If you are removing ISAless , i would suggest not to glue , but to buy 1 inch and 3/4 gas pipe plug and cut grooves with the grinder in it a little bit so it acts as a tap when you thread it into the plastic so it would hold and stay. Because I plugged mine with rubber and also jb welded it around , and recently rubber deteriorated and made a hole so I had huge vacuum leak.
Old 05-03-2017, 04:15 AM   #197
Blu302
Year: 98
Model: E46
HI,
thx
-f
The valve will sit at 50% open with no power.
1 coil opens it past 50%, the other coil closes it below 50%.
Old 05-03-2017, 05:16 AM   #198
fipse
My Ride: e46 330ci
[email protected]
that is what wanted to know..
Then i also don't trust any software close mods... If sth mechanical fails in the ISA i'm ed bcouse it will defently happen when i have no tools with me... (murphy's law u know...)
Still i'm going the way of the least work and i will just insert a rifled aluminium rod or sth into the tube before the valve. Hoseclamp on it - ready to roll
-f
Old 05-05-2017, 03:35 AM   #199
daniel_f.
My Ride: 330iC
I designed a plug to easier removing of the ISA/ICV. If anyone has a 3d printer which is capable of printing ABS filament, you can use this plug to seal the hole in the intake
http://www.thingiverse.com/thing:2297204
Old 05-05-2017, 07:44 AM   #200
Michel20
My Ride: 528iA LPG
Yaah very great, also thought about 3d scan. So i need one for (D)ISA and one for ICV? Könntest du mir die drucken?
