My 2005 330i zhp was running fine then power dropped and idle would surge from 1000 rpm to 1500 rpm. Did not respond to throttle. Checked engine codes and got P1635 and somtimes P1634 both about the throttle body adaptations. Did some searching didn't find much.
Took the car to the Dealer and their diagnosis was a bad DME caused by leaky cam sensors and Vanos solenoid causing oil to get into the DME/
Is this even possible? I am worried they are going to replace and the problem will remain.
Doubt you need a new DME. Most likely just need some electronic repair if anything. Beware the Stealer, they will often blindly replace parts to fix a problem while your wallet bleeds.
Probably not fried, its just the "easy" way out for the dealer. Clean out the oil from the connectors with brake clean(?) and it should be fine after another adaptation and code clearing
Wow thanks for the help. Seems weird but makes sense. So I am thinking I can clean the connections, try it and it should run for a bit until the oil migrates back in but i'll know that is the solution.
At least pull out the harness connector and inspect carefully with a bright light. Easy to do. This oil or coolant wicking up the wiring harness is fairly common on these cars. Another reason not to ignore any fluid leaks.
Related Threads
E46 Fanatics Forum
17.9M posts
592.8K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
