oil filter housing gasket? or just a defective oil filter o-ring - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-29-2019, 07:29 PM   #1
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
i swear i was planning to do the oil filter housing gasket as pm. i left the car for a couple of weeks and came back to this. i know this is a very common failure, but first time for me so i'd appreciate any advice. i'm hoping there is a bavauto diy blog or youtube video for this repair.
wfx32 is offline   Reply With Quote
Old 11-29-2019, 07:42 PM   #2
wfx32
My Ride: AWD
Transmission: auto
https://forum.e46fanatics.com/showthread.php?t=659100
found this old diy from 2009 and pics are still working.
Old 11-29-2019, 07:49 PM   #3
wfx32
My Ride: AWD
Transmission: auto
https://forum.e46fanatics.com/showthread.php?p=9614732
and another with still more pics.
Sponsored Links
Advertisement
Old 11-29-2019, 07:50 PM   #4
io14
My Ride: 05 325XI
50's Kid on Youtube has an excellent DIY on replacing the oil filter housing gasket.
io14 is offline   Reply With Quote
Old 11-29-2019, 08:01 PM   #5
wfx32
My Ride: AWD
Transmission: auto
thanks i will check that one out. his video quality is usually excellent. i didn't find a bavauto youtube but this bavauto blog recommends a viton gasket so you don't have to repeat the repair.
Old 11-29-2019, 08:23 PM   #6
wfx32
My Ride: AWD
Transmission: auto
the leak is so far forward .. i'm thinking it's leaking from the vanos line on the back of the oil filter housing.
Old 11-29-2019, 08:28 PM   #7
mrearly2
My Ride: '03 330i, Ilse
Transmission: 5 manual gears
Yeah, that's too high, to be a leak from the OFHG.
If it ain't broke, don't fix it.
mrearly2 is offline   Reply With Quote
Old 11-29-2019, 08:35 PM   #8
jmo69
My Ride: 03 325xi 98 328is
Have you changed the oil filter lately? Looks like the O-ring for the filter cap might be too far onto the cap. I got the O-ring above the groove once and it leaked like a sieve. The Vanos hose could be the cause too. Before I changed my OFHG the oil residue was mainly around the housing base and on the block not where it is in your pic. Might even be from the intake cam sensor O ring.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is online now   Reply With Quote
Old 11-29-2019, 09:40 PM   #9
Archbid
My Ride: 330ci Convertible
Year: 03
Transmission: 5-Speed Manual
That is a huge leak. I would use simple green and a brush to clear out the oil and watch where it is starting. You should still do OFHG, but you may also have issues with the Vanos oil line and potentially the valve cover - which if original should also be replaced
Archbid is offline   Reply With Quote
Old 11-29-2019, 09:41 PM   #10
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
When doing the OFHG it's a good idea to also replace the CCV parts as they're more accessible. Throw in the O2Pilot mod as well.
Old 11-29-2019, 10:32 PM   #11
wfx32
My Ride: AWD
Transmission: auto
last oil change was in march. i was just coming up on the 7500 mile oil change interval.
it doesn't seem to be leaking from the top of the oil stand. my guess is the crush washer on the vanos line but i will take it apart tomorrow to confirm.
i just replaced the CCV a couple of months ago. and i replaced the valve cover gasket and grommets a year ago. i regret both because now i am looking for an excuse to install the m56 aluminum valve cover.
Old 11-29-2019, 11:03 PM   #12
jmo69
You can run the CCV with the M56 cover, you'll just have 2 systems, the gaskets are different but the nuts and grommet are the same.
1998 328is 5sp
Old 11-30-2019, 02:07 AM   #13
OnTheFence
My Ride: 2001 330i (and 530i)
I wonder if that oil is pooled there from a sloppy oil filter change?
0714,0171: It was the MAF. NOT intake boots. NOT vacuum lines. NOT Fuel pump
OnTheFence is offline   Reply With Quote
Old 11-30-2019, 07:55 AM   #14
wfx32
My Ride: AWD
Transmission: auto
jmo suggested the same .. but it's been many months since the last oil change and i swear i installed the filter correctly.
reminds me of years ago when the independent left his mop up rag in the stand and then mashed the filter down with it. engine ran badly but no leaks back then.
i left the car garaged for a couple of weeks, worried that the coolant light and some minor coolant loss were precursors to failing thermostat or radiator as in years past.
so i was expecting to come back and find a coolant leak, not an oil leak. it's an active leak pouring out from somewhere .. so i should be able to clean up and trace as suggested by archbid.
Old 11-30-2019, 08:55 AM   #15
66intheSky
66intheSky's Avatar
My Ride: BMW
Year: 2000
Model: 328i ZSP
Transmission: Manual
^^^^^this.....looks like a sloppy filter change, cap wasn't torqued properly, or someone forgot or pinched the filter cap o-ring. OFHG leaks will be below on the webbed area on the block. PS I used the Bavauto Viteon OFHG and for about a year now its been bone dry under there. Fingers crossed lol.
66intheSky is offline   Reply With Quote
Old 11-30-2019, 12:14 PM   #16
lennard
If you still want to go ahead with the gasket change go and buy the gasket at the dealership... Where I live, they were a bit cheaper than the ones from Ebay.
Also it would be a good idea to also change the gasket between the oilfilter housing and the heatexchanger.
Aaaand if you are already at it, do yourself a favor and change the Vanos seals and the vacuumpump seals as well, they all dont cost much and mine were hard as glass after almost 20 years, so even if they do not leak now, they will probably start soon.
lennard is offline   Reply With Quote
Old 11-30-2019, 02:21 PM   #17
wfx32
My Ride: AWD
Transmission: auto
nothing wrong with the o-ring. i used the genuine bmw rubber this time instead of the white viton. nothing wrong with the vanos line or crush washer either. so yeah i must have not torqued it down properly.
Old 11-30-2019, 02:59 PM   #18
jmo69
I hope that's it, when I got the O-ring wrong it started leaking right away, not 9 months later. Mine had actually started to squeeze out because it was above the groove. As far as torquing it, I just crank it down till it seats, it's two flat surfaces meeting.
After looking at the pic closer it looks like the old O-ring was out of the groove.
1998 328is 5sp
Old 11-30-2019, 03:05 PM   #19
66intheSky
66intheSky's Avatar
My Ride: BMW
Year: 2000
Model: 328i ZSP
Good you discovered it before it spit more oil everywhere. Could you tell if it was loose when you unscrewed it?
Old 11-30-2019, 04:15 PM   #20
wfx32
My Ride: AWD
Transmission: auto
i guess better late than never. quite a mess. the cap was not at all loose when i removed. it was seated all the way down. but i can't find any other source of the oil unless the stand itself is cracked.
yeah i can't figure why it was ok for months and then started leaking after parked for two weeks.
why do you say that? the ring was in the groove when i unscrewed the cap.
