Why you should change your Steptronic Tranny Fluid before 100k (pics) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-26-2009, 04:58 AM   #1
Luky
My Ride: '08 335i RIP'03 330i
Exclamation Why you should change your Steptronic Tranny Fluid before 100k (pics)
I did the steptronic tranny filter and fluid change last summer and took a bunch of pics and kept meaning to post them (so here they are). There are some great DIY threads on here that I don't need to repeat (just use search ), just wanted to show my results...
I did not use the super expensive BMW LT71141 fluid, but some Castrol Import Multi-vehicle ATF that said it met the same specs as the LT71141 and was only $4 a quart at Kragen (not the $25/QT from BMW). I have about 12k miles on this fluid so far and no issues with the tranny or shifting (and I drive the crap out of my car - use the sport/manual mode most of the time). Very glad I did it as the fluid that came out at ~63k miles was black and I believe it would have been very bad to let it go to 100k. The fluid was so cheap that I simply drained it with the drain plug, refilled it (just a couple of quarts), ran it for about 5-10 min while running through the gears, and repeated this four times to insure that I changed all the fluid in the torque converter (4th time the fluid came out cherry red "clean"). Then I dropped the pan, changed the filter, and filled it up, ran through the gears etc. Then I drained about 1.5 qts just to check it again and then topped it off per the procedure.
The pictures just show a little in the bottom of the bucket as I was trying to show how it got more translucent as I kept flushing it out.
I have also been using this fluid for my power steering as well. I noticed it was looking a little dirty and I was getting some "squealing" when turning the wheel, so I use a turkey baster to suck out the reservoir and then refill it. I have done this several times over multiple weekends to try and "renew" all the fluid without the hassle of draining the whole power steering system. The fluid I get out now looks clean and the "squealing" has stopped and everything is running fine.
Obviously YMMV, but the inexpensive Castrol ATF has worked fine for me...
Name:	ATF bottle.jpg
ID:	312459   Click image for larger version
Name:	first drain and new.JPG
ID:	312460   Click image for larger version
Name:	second drain.JPG
ID:	312461   Click image for larger version
Name:	third drain.JPG
Name:	fourth drain and pan drop.jpg
ID:	312463   Click image for larger version
Name:	final drain 1.5 qts.JPG
ID:	312464   Click image for larger version
Name:	first drain.JPG
Luky is offline   Reply With Quote
Old 04-26-2009, 09:27 AM   #2
kent330i
My Ride: 2005 330i ZHP
Send a message via AIM to kent330i
Nice Job! Mind if you can tell me how much it drains and fill each time? (about 2 qt)?
Thanks.
kent330i is offline   Reply With Quote
Old 04-26-2009, 07:16 PM   #3
Luky
Thanks.
Sorry, its been so long since I did this I don't remember specifically. I think it was more like 3-4 qts each time. May have only been 2 qts each time... I do remember you can get more out of the pan if you jack the back end of the car up higher (it was sitting level on 4 jack stands).
Sponsored Links
Advertisement
Old 04-02-2010, 12:46 PM   #4
Luky
Update... Now at 86k miles and no issues with the tranny. The Castrol Import Multi-vehicle is working just fine...
Old 04-04-2010, 11:07 AM   #5
Cinna
My Ride: M3C
Send a message via AIM to Cinna
be sure to keep the maintenance up! I would do the service again once you get near 100k miles, about every 40k.
E46 M3
Cinna is offline   Reply With Quote
Old 04-03-2019, 10:36 PM   #6
Toni57
Banned User
Awesome
Do you recommend me taking mine to a quick lube for the change ? I want to get the same outcome as you did with yours I just canít do it myself
Toni57 is offline   Reply With Quote
Old 04-04-2019, 10:54 AM   #7
Luky
Funny how old threads live forever. Have not had this car for about 10 years... (Have had an 2008 E90 335i, 2013 F10 535i (totaled), 2011 G37S, and now a 2016 F10 550i since then). Yes I would get it changed. Don't know if they would do it the way I did it. They may have a machine that drains from the tranny and puts new fluid in at the same time (flush) using oil cooler lines. Talk to them about what you want done (full flush and new filter) and how much it will cost and make sure the fluid they are using meets the BMW Spec for your transmission.
Old 04-05-2019, 08:54 AM   #8
markusmarkus
My Ride: 2018 M240i
Never take your car to a quick lube joint! The people working there donít have the training nor the proper equipment to properly do the job. Find a reputable indie shop that specializes in bimmers at www.bimrs.org. Modern automatic transmissions require that the fluid level be within a small range. To achieve this the transmission temperature has to be with a specific temperature range. Over- or under-filling an automatic transmission is a definite no no.
Old 04-16-2019, 07:52 PM   #9
Toni57
Banned User
Thank you
Old 11-10-2019, 10:09 PM   #10
swordsman11868
My Ride: 2003 325i
Transmission: Autotragic
I'm just here to change the world.
BMW Wiki:
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
