The Permanent M54 CCV Delete - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 02-18-2016, 05:13 PM   #81
rkneeshaw
My Ride: 330i ZHP
By the way, I scored a M56 valve cover for $175 shipped, from a auto recycler on car-part.com, woot! Its a website that searches junk yard inventories. You have to call around and verify that the valve cover they have for a 2003 325i has the oil cap in the corner (M56), or in the middle (M54).
Price of a new M56 valve cover is like $600 everywhere I looked.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2+ - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - Hawk Performance
Build thread:
Wheelwell:
Fuelly:
rkneeshaw is offline   Reply With Quote
Old 02-22-2016, 07:32 PM   #82
rkneeshaw
My Ride: 330i ZHP
Here she is, cleaner than I had expected, but I'll still give it a good solid cleaning
And someone asked about the oil cap. The m54 oil cap works, sortof. I know why its a different part number. The M56 oil cap rotates off and then is hinged, so it flips open. The M54 cap will fit but it doesnt close squarely. I was able to put the M54 oil cap on with the M56 cap still attached and flipped open, this is the M54 cap fully tightened:
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Old 02-25-2016, 08:34 PM   #83
rkneeshaw
My Ride: 330i ZHP
Hey has anyone found the need to buy some of those "standoff" screws for the plastic cover to properly mount to the valve cover and on top of the fuel rail? its item #6 here:
I assume they just screw into the two threaded holes on the M54's fuel rail that my stock M54 plastic cover uses? OP must have just let the right side of the plastic cover float without them...?
Updated parts list for 2003 and later M54 guys:
Metal M56 valve cover (11127521086) $300 if your lucky, $600 MSRP
Top valve plastic "BMW" cover (13537515326) $140
Standoff screws/mounts for the plastic cover x 4 (13537515327) $40
Rubber grommets for standoff screws/mounts for the plastic cover x 4 (11127501588) $10
VCG (11127521009) $60
Spark plug gasket (11127521010) $20
VCG o-rings x 11 (11121437395) $15
Oil cap (11127500568) $10
Plastic connector hose (11157513756) $53
Re-use existing coils and ground straps
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Sponsored Links
Advertisement
Old 02-26-2016, 03:25 PM   #84
Andy325is
My Ride: 90 325is & 94 D90
You'll only be able to install the 2 standoff screws on the valve cover. (A new valve cover does not come with the standoff screws contrary to what's depicted in the ETK, so they must be ordered separately.) The other 2 are installed on the intake manifold. You can't install the M56 intake manifold because it uses special fuel injectors. A tuner might be able to program your DME to utilize the special injectors, but IMO not worth the effort.
Andy325is is offline   Reply With Quote
Old 02-26-2016, 03:36 PM   #85
Andy325is
I have an M56 valve cover + beauty cover for sale in the classifieds: https://forum.e46fanatics.com/showthread.php?t=1098500
Old 02-27-2016, 04:17 PM   #86
rkneeshaw
My Ride: 330i ZHP
Thanks Andy, that's interesting. The M54 covers screw into threaded holes on the fuel rail itself. Guess they changed their mind with the M56. Bummer.
In other news, I opened up the covers on the underside of the M56 valve cover, and given how clean it is on the post-CCV side of things I'd say the CCV must do a pretty good job:
Also, I used a small screwdriver and very carefully was able to remove the CCV cap. Here's what's inside:
Its such a very simple contraption. The only way I could see this failing is if you had some really nasty thick gunk in there, but then, you probably had other issues too
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Old 02-27-2016, 08:00 PM   #87
Andy325is
Hey thanks for posting those pictures of the inside of the CCV. That's pretty cool. It looks a lot like the N62 CCV. Have you tried to see if the cap from the N62 CCV repair kit (11127547058) will fit on there? It looks like the other pieces wouldn't work though. The spring looks shorter on the N62.
Old 02-27-2016, 08:42 PM   #88
rkneeshaw
My Ride: 330i ZHP
I don't think it will, based on careful examination of the photos. The N62 CCV cover's tabs are all equally spaced around the cap, but the M56 CCV has 3 "groups" of tabs that kind of form a left and right set of tabs. And the diaphram looks different, one has holes and a nipple, the other has no holes and a flat surface.
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Old 03-02-2016, 02:03 PM   #89
PabloCruise
My Ride: 2002 325i
Year: 2002
Model: 325i
Transmission: Auto
Originally Posted by Sansho View Post
So, if one were to buy all the parts new (with discounted BMW dealer prices and Pelican Parts on coils), required for a pre-09/2002 e46, this would be an $875 project:
Coils ( 6 @ $38) = $228
Spark plug wiring harness $112
Metal valve cover $297
Top valve plastic "BMW" cover $140
VCG o-rings (11 @ $1.36) $15
Oil cap $10
Plastic connector hose $53
Ground strap $20
Total $875
Those with 09/2002 and later could get away with $535 for the new parts.
Darn, having to change coils on my 7/02 build e46 makes this fairly expensive looking...
PabloCruise is online now   Reply With Quote
Old 03-02-2016, 02:10 PM   #90
daniel_f.
My Ride: 330iC
Did you guys notice the different partnumber for the suction pump? Did anyone change that too?
Current licensing status:
Security implementation *done*
Implementing Flex Fuel
Old 03-02-2016, 04:55 PM   #91
Andy325is
It looks like the sucking jet pump itself is the same, but they integrated the fitting on the end that plugs into the intake manifold to probably help eliminate hydrocarbon escape via the intake system. You'd need that new sucking jet pump if you installed the M56 intake manifold along with the injectors & fuel rail, and also a 5 bar fuel pressure regulator. That quick connect fitting won't attach to the M54 intake manifold.
Old 03-02-2016, 09:27 PM   #92
rkneeshaw
My Ride: 330i ZHP
What sucking jet pump are you guys talking about? is that the secondary air pump (SAP)?
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Old 03-03-2016, 01:25 AM   #93
daniel_f.
My Ride: 330iC
So consensus is to stay with the M54 part? Fine, saved another 50
The one that does vacuum for the brake booster
Old 03-31-2016, 01:03 PM   #94
Andy325is
I attached the M56 hose from the valve cover to the M54 hose coming from the air distributor so that the hose that goes to the other side of the air distributor can stay intact, for equal pressures across the intake. I used a 3/4" 90 degree barbed brass elbow linked to the hoses with some 1" heavy wall 3:1 adhesive heat shrink tubing. I used super glue to temporarily hold the pieces together. I used new hoses and I installed a new air distributor as well because the air passages can get clogged with gunk.
Old 04-14-2016, 11:58 AM   #95
XavierBK
My Ride: 2001 325i
Originally Posted by PabloCruise View Post
Great thread! I am not sure if the CCV has ever been replaced on my 2002 325i (~128k miles)
I too am wondering about the connection to the M56 valve cover - where does this plug in?
Well earlier in the thread it was pointed out that there is a new shorter CCV breather hose part number that can be used to connect the nipple on the M56 valve cover to the port on the intake manifold.
But I don't have the stock intake manifold anymore because I have the ESS TS2 kit installed. It has its own hose that runs from the stock M54 valve cover to it's PCV. I'm wondering if that same hose will simply connect onto the M56 valve cover, which would mean the "nipple" would need to be the same.
Another question to ask to get the answer I need would be if anyone knows if the new shorter CCV hose has the same connector as our stock M54 CCV breather hose? It's simply a shorter breather hose?
Hey did you happen to notice of the connector is different on this new breather hose, or did you only have to get a new one because of the length (and routing of the hose)?
I'm wondering if my M54 breather hose will connect right onto the M56 cover's "nipple" just the same or not...
No, the M54 hose will not fit the M56 valve cover. The M56 valve cover nipple is the same OD as the M54 hose.
XavierBK is offline   Reply With Quote
Old 04-16-2016, 11:10 PM   #96
rkneeshaw
My Ride: 330i ZHP
same OD, but the M54 hose wont fit the M56 cover?
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Old 04-17-2016, 10:25 AM   #97
XavierBK
My Ride: 2001 325i
Again, the M56 valve cover nipple is the same OD as the M54 HOSE, not valve cover nipple. The HOSE that fit INTO the M54 VC is the same size as the nipple on the M56 VC. So no, it doesn't fit.
Old 05-20-2016, 09:56 PM   #98
rkneeshaw
My Ride: 330i ZHP
Installed!
or
M56 valve cover gasket is so much easier to install than the M54.
Thanks xavierbk for clarifying the hose size, saved me from being stuck.
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Old 05-20-2016, 10:16 PM   #99
XavierBK
My Ride: 2001 325i
No problem, glad I saved someone from the headache I went through. Ended up buying some hose, clamps, and elbows to make a hose myself.
Never posted a pic of mine installed in this thread. This isn't completely back together and before I fixed the hose.
Old 05-22-2016, 12:22 AM   #100
rkneeshaw
My Ride: 330i ZHP
Dang I love that yours is black like that! Did you have it powder coated or did you spray paint it?
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
