Turbo project for a budget - Page 6 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-02-2017, 02:13 PM   #101
daniel_f.
My Ride: 330iC
Is the charger ok for 12psi?
No further development on MS4x from me.
Old 05-03-2017, 10:16 AM   #102
cwarel
My Ride: 330ci coupe
Turbo i got is too small
cwarel is offline   Reply With Quote
Old 05-04-2017, 10:02 AM   #103
Pole position
My Ride: E46 330ci
What size is it? I never had issues with a gtx3076r china clone, but just got a 6262, yet to try it though.
Want my old turbo? I can sell for cheap, needs external wastegate though.
Shut up and drive
Pole position is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-09-2017, 10:31 AM   #104
cwarel
Nah its all good , i got cx racing one coming that has exhaust housing 3 inch
Old 05-09-2017, 10:36 AM   #105
cwarel
Also Im gonna start a series of cheapo engine rebuild for boost )) cuz my bastard burns 1 liter of oil a day ))
Some info I need right now
Which piston rings to get
and which is the best time cert kit with bigger size bolts.
Pistons will get shaved a little maybe , MLS HG
Deck block and head
Port head
M50 manifold
600 whp on stock internals till it blows or not , if it doesnt blow on 600 whp while im daily ripping it imma go higher untill it does and then ill get pistons and rods.
Old 05-09-2017, 03:00 PM   #106
cosmos328Ci
My Ride: 400+whp. 500.4ftlb
Transmission: 5 Speed Manual
Oil rings on your pistons: Use M52TU, old style three-piece. (avoid M54 oil burning)
Head gasket: I hear these days is to go for the cut-ring style when running boost.
I think any Time-serts - I have 11mm and S54 head bolts I was thinking of using. (not sure if I will go there yet)
Looking forward to your Destructive Test results.
M54B30, ESS TS2 Manifold, 4" Throttle Body, 108mm pulley - 4.25".
cosmos328Ci is offline   Reply With Quote
Old 05-10-2017, 12:38 PM   #107
Pole position
My Ride: E46 330ci
My stock motor was fine and I ran up to 19psi so it's going to take a lot to blow
Try rotella t6 to reduce oil burning
Shut up and drive
Old 05-10-2017, 06:56 PM   #108
cwarel
19 psi with completely stock engine ? on 93 gas ?
Old 05-10-2017, 07:13 PM   #109
Pole position
My Ride: E46 330ci
E85
Shut up and drive
Old 05-11-2017, 09:36 AM   #110
cwarel
E85
Well for me to get e85 i gotta drive for a while and pay a 14 dollar toll ))
Old 05-11-2017, 09:38 AM   #111
Pole position
My Ride: E46 330ci
Bring some fuel jugs, big boost is unreal. Seriously unreal.
Shut up and drive
Old 05-11-2017, 09:57 AM   #112
cwarel
If I get e85 i need bigger injectors , Ive got walbro 450lph fuel pump
I just cant find injectors that would work with stock ecu with no problem
like it has to 14.9 ohms saturated , otherwise I gotta do resistor box and get peak and hold injectors
Old 05-15-2017, 06:37 AM   #113
cwarel
Anyone can throw a suggestion for piston rings for OEM pistons so it stops oil burning? I know that m52tu are the answer , but question is , if all the rings fit the piston?
Old 05-15-2017, 09:10 AM   #114
cosmos328Ci
No, only the oil rings.
Old 05-15-2017, 09:56 AM   #115
cwarel
So I only have to get oil rings from m52tu and the other 2 rings can be stock?
Can you please throw a link for it.
Old 05-15-2017, 06:31 PM   #116
avantgarde
My Ride: 2001/2005 325xi A/M
from what I gathered in my procuring of information, yeah. M52TU rings will fix the oil burn issue prevalent in e46s.
avantgarde is offline   Reply With Quote
Old 05-16-2017, 11:34 AM   #117
cwarel
Nah I meant i need the link where I could either buy m52tu oil rings separately or just a link , cuz I dont feel like getting the whole set for m52tu and m54 that will be 250 bucks.
Old 05-16-2017, 12:14 PM   #118
avantgarde
Oh, you should have said that, LOL! I have these sitting in my cart on eBay.
http://www.ebay.com/itm/OIL-RING-SET...5YJPuy&vxp=mtr
I already messaged the seller, they confirmed it is the normal style 3piece oil ring set from M52, not the 2 piece from the M54. They can put other pieces from the M54 together with the M52 oil rings if you want to do that. Just contact them through eBay.
Old 05-16-2017, 12:25 PM   #119
avantgarde
If you're looking for pistons, just contact Ross... They have an assortment of BMW pistons for not a whole bunch of money. As it stands, the M50-series engines are not as high compression as the numbers say. The B25 is actually around 9.6:1-ish where as it's advertised as 10.5:1.
Old 05-18-2017, 07:33 AM   #120
cwarel
So updates again
1) Started pulling that engine in the backyard , got to the point where its just a long block. Couldnt take the head off because I had no e12 socket, it already came 12 bucks on amazon))
2) Ordered ARP studs 225$
3) Cometic Head Gasket from vac motorsports for around 250 with the shipping , came in 2 days , gasket thickness is 0.098
4) Ordered those m52tu oil rings ( gotta order regular m54 set I guess too )
5) Supertech valve stem seals , never tried them before seems to be legit. Intake side is made of polyacrilic and exhaust side is viton which is oil resistant rubber ) Cost about 32 bucks on good ol ebay
Updates on the car
So everytime I drive I sort of lose 4 quarts of oil a day ( ab out 100 miles ) So far I know that CHINESIUM turbo took a crap for sure , Valve cover leaking too I think , Oil pan dipstick - I lost the oil ring for it somehow , I placed one in there and I cant tell if it stopped pissing out oil or not. 2 Other reasons why my car hates oil is definitely piston rings and probably valve stem seals are crapped out too ( because the car was sitting for 7 years in florida sun)
Good news is that I think my car is in autolearn mode or somesort , because I still havent finished the tune ( lazy me ) and it seems like its driving better the more I drive .
