Temperature shooting up and down need help!! 03 325Ci - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-20-2014, 05:13 PM   #1
thiagooo
Hi I just bought a 03 325Ci and now the temperature keeps shooting up to red then as soon as it reaches the red it goes back to the middle and it keeps doing that, it goes to red too quickly before to motor can actually even heat up, has this happened to anybody else? If so what was it?
I did a little research and mostly it said that problem is a bad thermostat and some said sensor...but mostly thermostat....
If any kind soul out there can help me please do lol
thiagooo is offline   Reply With Quote
Old 05-20-2014, 06:31 PM   #2
Yewzer B Lewzer
My Ride: 2003 325i
You may have trapped air in the system, or worse a blown head gasket.
Look for Mango's sticky thread on cooling systems and follow the bleeding procedure for starters.
If it's a blown head gasket I would making a visit to the previous owner.
Window Regulator Help:
Axle Shaft Replacement:
Red Oil Light!!:
MrPhilidelphia’s Temperature Gauge Improvements:
Yewzer B Lewzer is offline   Reply With Quote
Old 05-20-2014, 06:39 PM   #3
thiagooo
Alright thank you brother
Sponsored Links
Advertisement
Old 05-20-2014, 07:57 PM   #4
greenskycity
My Ride: 1999 328i
Had a weird issue like that the other day. On a country drive I noticed that my temp was in the red but the light wasnt on. My tach was at like a 1200 rpm at idle and my speedo said I was doing 20 mph while stopped. I'd ripped off my ambient air probe again and thought that might have been it.
I turned the car off abd the needles stayed where they were. I shorted the temp probe wires together and pulled the battery negative cable, after reattaching it, all was normal again except my outside temp read 121*.
I'd say pull the battery first, maybe change the temperature sensor and then bleed the system. If it's moving to red on cold starts and back, might be something easy.
Good luck,
Green.
greenskycity is offline   Reply With Quote
Old 05-20-2014, 08:45 PM   #5
lszlszx
My Ride: Z3, V50, 1.8T
Find out the history of the car. Did the PO work on it?
Did he tell you about the problem? Is there a lemon law in your state?
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-21-2014, 09:29 AM   #6
teamdfl
Slow in, slower out
My Ride: 325it
Those are typical symptoms of air in the cooling system.
Real racers race LeMons
teamdfl is offline   Reply With Quote
Old 05-21-2014, 10:27 AM   #7
orb
My Ride: 325Ci
Doesn't the lemon law only apply to new cars?
orb is offline   Reply With Quote
Old 05-21-2014, 11:59 AM   #8
hummer
My Ride: 2001 330CI
Sounds like a bad temperature sensor or loose wire connected to it?
