Who has put a catch can in their E46? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-23-2020, 10:23 AM   #1
Kneedspeed
My Ride: 2001 330Ci Vert
Year: 2001
Transmission: manual
If so, I'm looking for a recommendation.
of course, I've viewed the 50s kid how-to videos but he used a Ebay special for $20 that backfired on him (had a flaw leading to vacuum leak)
I don't really want to shell out $250 on the bigger kit so I'm wondering if there's something in between.
Thanks.
Current: '01 330Cic vert ZSP Manual-5, '17 Vette C7Z06 targa Manual-7, '11 Acadia Denali SUV,
Past: '17 Vette C7GS targa Auto-8, ‘10 Bentley cont gt SS, '10 Lexus IS250 Vert, '99 986 Boxster Manual-5, '14 Mustang GT Auto, '98 MB E320 sedan
Kneedspeed is offline   Reply With Quote
Old 01-23-2020, 10:54 AM   #2
2EROFUK5
My Ride: E46 330CI
just buy a can without this stupid level meter. it's cheap.
and YES, this is a MUST mod. my M54 completely stops eating oil after the CCV delete.
2EROFUK5 is offline   Reply With Quote
Old 01-23-2020, 12:10 PM   #3
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
catch can has been recommended to me many times, and i'm sure it works but i still haven't tried it .. i guess because of the maintenance of emptying the can and the fact that there are so many good CCV alternatives: O2 pilot mod, PCV, larger M5 CCV, M56 valve cover.
wfx32 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-23-2020, 12:16 PM   #4
LukeBMW
My Ride: 2005 BMW 325Ci
Year: 2005
Model: 325Ci
Transmission: GM A5S390R
I did put a catch can for my car. My car still burning oil 1 quart for 1,700 miles. I bought on ebay for $21. It's pretty good oil catch can. ebay item # 254174623445
LukeBMW is offline   Reply With Quote
Old 01-23-2020, 09:01 PM   #5
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
No catch can on either the E39 or the E46, but both have the O2Pilot mod and minimal oil consumption.
Old 01-23-2020, 09:08 PM   #6
jmo69
My Ride: 03 325xi 98 328is
Try this and eliminate the ccv, my friend has it on his dad's e39 m54b30 and works really well, good crankcase vacuum too. https://xoutpost.com/bmw-sav-forums/...-problems.html
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
jmo69 is offline   Reply With Quote
Old 01-24-2020, 12:58 AM   #7
TobyB
My Ride: 2004xit, 2001ci
I've just changed out the front and rear main seal-
you really don't want much negative pressure in the crankcase.
Those flimsy little things won't stand up to 15 inches of mercury.
In retrospect, I should have sourced real seals, the kind that don't go hard
and leak like old rope seals did. Maybe next time.
t
not.impressed.with.'progress'.
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
Old 01-24-2020, 10:06 AM   #8
Kneedspeed
Year: 2001
After doing some more research, I'm now sold on the O2pilot mod for the concept and relative convenience vs the catch can.
This should be good enough for me- I'm not shooting for 0 oil consumption, just want a marked improvement.
Thanks to everyone for the input!
Old 01-24-2020, 12:51 PM   #9
Silverdogz
My Ride: '02 330Ci, '04 330i
Year: 2004
Model: BMW 330i ZHP
Transmission: Manual 6spd
I did the M56 cover over a catch can or the O2Pilot mod. This is because I think the O2 mod puts way too much negative vacuum in the engine, and could cause RMS damage and leaks.
DSC MK60 Replacement and INPA Install:
Silverdogz is offline   Reply With Quote
Old 01-24-2020, 02:28 PM   #10
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Maybe you’re thinking of the CCV bypass mod as documented on xoutpost? The O2Pilot mod simply connects a small vacuum line from the oil separator port to a port on the back of the IM. Crankcase vacuum goes up a bit, but not a lot like that other bypass mod.
Old 01-24-2020, 03:52 PM   #11
Daniel.
My Ride: 330i
Year: 2004
Next time my CCV needs replaced im going to try and fit provent 100 in its place
Daniel. is offline   Reply With Quote
Old 01-24-2020, 05:09 PM   #12
bendoscopy
My Ride: 330Ci M + 320Ci
Transmission: 5MT
I put a catch can in my 320. My oil consumption was pretty bad, even by BMW standards, and the O2 pilot mod didn't do enough.
I used what's been called the "E90" catch can, which made a great difference and has been bullet proof since fitment. I fabricated a bracket and mounted it in one of the drug bins.
Also included a PCV valve.
Only down side was the change in engine tone.
Sent from my Pixel 3 XL using Tapatalk
BMW E46 330Ci M-Sport 2001 topasblau/grau 110k miles
BMW E46 320Ci Sport 2002 topasblau/hellbeige 125k miles
| drive tastefully
bendoscopy is offline   Reply With Quote
Old 01-24-2020, 05:25 PM   #13
Delaxo
My Ride: E46 320i
Year: 2000
Model: e46
Transmission: Automatic
https://germanautosolutions.com/stor...TqdYYgeOmXAavU
Delaxo is offline   Reply With Quote
Old 01-25-2020, 11:59 AM   #14
TobyB
Yeah, the 02 pilot 'mod' really only adds a little crankcase vacuum, NOT full intake manifold. 40 inches of water, or so, which is less than 2 psi.
And only at off- throttle, when the cars tend to burn the worst.
It was only an incremental improvement in mine, but changing from M1 to T6 helped, too.
I was going to try the 'N54' can that's all over ePay- more for diagnostics than anything else. I'd love to find a clear
cyclonic version, but didn't have much luck finding something that wasn't just an air line filter.
t
- Hot Tub
Old 01-28-2020, 10:45 PM   #15
jmo69
Originally Posted by Delaxo View Post
That is definitely the ideal way to go. If it had been available when I did the M56 valve cover I would have done it, I spent nearly that much doing the cover mod. I was more concerned about the ccv freezing and hydro locking th motor, my oil consumption is 0 burned, some leaked.
Old 01-29-2020, 12:13 AM   #16
Silverdogz
Year: 2004
Model: BMW 330i ZHP
mhm, I ended up saving about 200 bucks when I did mine vs the G.A.S kit. Plus I like using BMW parts this way.
Old 01-29-2020, 09:15 AM   #17
Knight
My Ride: SL63 | SHO | E46
I'm giving the "BavarianE39" CCV bypass modification a try this week. If that doesn't work, then I will scale up to a catch can (have one ready).
Knight is offline   Reply With Quote
Old 01-30-2020, 10:38 AM   #18
Kneedspeed
Year: 2001
Thanks for all the discussion and suggestions. Now I have some options after the o2pilot mod fails miserably!
Old 01-30-2020, 03:58 PM   #19
HelloNewman
My Ride: 2 x 2003 318i E46
Year: 2003
Model: E46 318I Executive
Transmission: Auto Steptronic
That is a very tidy install. I wish I had E46 OCD to be like you.
Sorry if my questions seem that I lazy. I am ridden with arthritis. So bending over to look for a part I try to reduce the pain by asking here. No pity needed.
HelloNewman is offline   Reply With Quote
Old 01-30-2020, 03:59 PM   #20
smolck
My Ride: 2003 330ci (manual)
I did it. Vids found on my youtube page
Check out my BMW Blog
Check my Youtube channel for DIY's and fun stuff
smolck is offline   Reply With Quote
