Coolant brands? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-30-2019, 08:42 PM   #1
Tnelsen707
My Ride: 2005 325ci convertib
Coolant brands?
I’ve heard that the e46 is very touchy with any other kind of coolant other than the specific Bmw brand but what actually happens if you were to put a different coolant in even if it is still “safe for bmws”?
Tnelsen707 is offline   Reply With Quote
Old 11-30-2019, 08:56 PM   #2
Brewtus79
My Ride: M3 Vert, 330xi, X5
Year: 2002
Model: M3, 330xi, F15 X5
Transmission: 6 spd manuals
Risk vs reward. Why risk an adverse reaction with a coolant other BMW?
Sent from my SM-G950U using Tapatalk
Brewtus79 is offline   Reply With Quote
Old 11-30-2019, 09:16 PM   #3
Spannerhead
My Ride: '02 330i/5 slicktop
Originally Posted by Tnelsen707 View Post
I've heard that the e46 is very touchy with any other kind of coolant other than the specific Bmw brand but what actually happens if you were to put a different coolant in even if it is still "safe for bmws"?
It's not touchy with other brands, but I'd at least make an effort to put in all one color or the other. Just don't put in the orange stuff.
I use Peak or Prestone 50/50 premix. Very convenient to buy, cheap and I never have to worry that I got the ratio wrong when pouring. 45K miles and no problems whatsoever (and it was a brutal summer here in TN).
Current:
Past BMWs:
Past Other: '85 GSL-SE • '88 JZA70 • '86 4K quattro • '85 RX-7 S • '85 RX-7 GSL
Spannerhead is online now   Reply With Quote
Sponsored Links
Advertisement
Old 11-30-2019, 09:20 PM   #4
TobyB
My Ride: 2004xit, 2001ci
Don't mix types, and change it every couple of years.
Any antifreeze/coolant for aluminum/ iron engines works.
I use prestone, too, simply because it's easy to get.
There's nothing wrong with the BMW stuff, except that I find it pricey and hard to locate.
t
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
Old 11-30-2019, 10:16 PM   #5
horse
My Ride: 2001 330ci
Zerex G-48 is the same as Genuine BMW, and O'Reilly's stocks a 50/50 mix (although it's cheaper to buy straight coolant)
horse is offline   Reply With Quote
Old 11-30-2019, 10:51 PM   #6
Jagdtiger
My Ride: 05 330CI
I've used peak for a long time now. No problems with it.
Jagdtiger is offline   Reply With Quote
Old 12-01-2019, 06:24 AM   #7
74123
Guest
My Ride: 320i SE Coupe
https://www.amazon.co.uk/dp/B003BPNO...395841_TE_dp_1
74123 is offline   Reply With Quote
Old 12-01-2019, 06:29 AM   #8
markusmarkus
My Ride: 2018 M240i
Originally Posted by RayPooley View Post
Yikes, that’s expensive.
Old 12-01-2019, 06:31 AM   #9
wasp9166
My Ride: 04 330i jet black
zerex g-05
"if polarity comes from protons, does morality come from morons?"
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 12-01-2019, 07:48 AM   #10
74123
Guest
Good stuff though. And it's not like you are using it up every day.
Old 12-01-2019, 08:26 AM   #11
cvx5832
My Ride: 535i, 325Ci, C300
Prestone 50/50. Nitrate, borate and silicate free. The days of “use BMW blue or your cooling system will explode” mango days are long gone.
The LL-01 groupies however may take another couple years to break up.
cvx5832 is offline   Reply With Quote
Old 12-01-2019, 02:19 PM   #12
jmo69
My Ride: 03 325xi 98 328is
Pentosin is acceptable but can get pricey, I see it locally but in small containers. I have an indy that sells BMW for $26/gal. $1 for distilled water and it becomes $13.50/gal. Amazon has it cheaper right now. https://www.amazon.com/BMW-821414677...xpY2s9dHJ1ZQ==
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
jmo69 is offline   Reply With Quote
Old 12-01-2019, 05:38 PM   #13
LL i am
My Ride: 2001 325ci
looks like safe for a lot of people.
i'm on BMW blue since day 1.
i'm using the coolant as a filler for free shipping
LL i am is offline   Reply With Quote
Old 12-01-2019, 05:42 PM   #14
TerraPhantm
My Ride: M3
I mean you can use whatever you want, but unless it’s an emergency there’s no real advantage to deviate. The bmw stuff is pretty cheap and performs adequately.
Old 12-01-2019, 08:28 PM   #15
Cheap Trick
My Ride: E46
Year: 2002
Model: 330ci cabriolet
Transmission: auto
zerex G-05 easy to find and relatively inexpensive. Now if I could just find some "BMW" washer fluid so my special BMW windshield won't melt.
Cheap Trick is offline   Reply With Quote
Old 12-02-2019, 11:00 AM   #16
docnabimmer
My Ride: 2004 325XIT
Year: 2004
Model: 325XIT
Transmission: standard
OP---lets be real here... if you choose generic medicines and products over THE BRAND NAMES to use for yourself why not with this ancients??,,, its the same thing especially with your car,just buy a non BMW phosphate free nitrite free amine free silicate free coolant-your car will be fine.
But if you want to spend money ,that is okay too,,,in that case BUY everything BMW...
docnabimmer is offline   Reply With Quote
Old 12-02-2019, 01:36 PM   #17
Newbimer
My Ride: 2005 325i
Locally the OEM is around $30/gallon. It does not say if that's a gallon of concentrate or its a 50/50 mix. If 50/50 its way over priced. I get a gallon of concentrated Prestone for around $18.00 and mix it myself with distilled water ($2.00/gallon). So I make 2 gallons 50/50 at @$9.00/gallon. With the OEM the cost is about double that @$18.00/gallon. I've never had any problems using the Prestone, has always worked great for me.
Newbimer is offline   Reply With Quote
Old 12-02-2019, 05:17 PM   #18
Knight
My Ride: SL63 | SHO | E46
Why the right coolant is important: https://blog.fcpeuro.com/how-to-pick...t-for-your-car
$22/gal for concentrated OE coolant with a lifetime replacement: https://www.fcpeuro.com/products/bmw...ze-82141467704
Zerex G-05 is a great coolant that meets spec (and also costs the same).
Peak also released a manufacturer-specific line of coolant options.
Bottom line: The OE option is cheap to begin with. If you go with something else for whatever reason, at least make sure it meets spec.
Knight is offline   Reply With Quote
Old 12-02-2019, 09:34 PM   #19
smolck
My Ride: 2003 330ci (manual)
I am no Mango fan, but I do work on a LOT of BMW’s and my best friend owns a BMW shop, and we both agree we see more failures on green coolant cars than blue. It’s subjective to some extent, but based on 20 years experience. Now that Advance and Autozone carry the “blue stuff” for reasonable prices, I see no reason NOT to use the blue.
That said, replacing your cooling system PARTS every 70k is the only surefire way I know to almost eliminate cooling system problems.
Check out my BMW Blog
Check my Youtube channel for DIY's and fun stuff
smolck is offline   Reply With Quote
Old 12-02-2019, 09:45 PM   #20
docnabimmer
Year: 2004
Model: 325XIT
Hopefully the OP will develop good habits - based on what he is comfortable with and common sense .Now lets go post about what oil brand to put in our cars....
