Power Steering Fluid confusion - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-28-2018, 05:57 PM   #1
Chasepinkonsly
Okay so I have a 2004 325i with 179,000 miles and I'm going to change the power steering fluid. My lid says "ATF" so do I use any Dex 3 tranny fluid or do I use Pentison CHF 11s?? Or does it really matter that much
Chasepinkonsly is offline   Reply With Quote
Old 10-28-2018, 06:02 PM   #2
LeverThis
My Ride: 2004 325i automagic
Dex 3 or Dex 6, whatever is on sale. Check the current fluid in there, it should be a dark reddish color indicating atf.
BMW seems to recommend chf 11s for everything now because that's what the newer cars use, but it is NOT compatible with atf. Do not mix the two and use only atf
LeverThis is offline   Reply With Quote
Old 10-28-2018, 06:09 PM   #3
Chasepinkonsly
Alright thanks man! Now what tranny fluid should I use like which brand is best? Probably doesn't matter that much but I used Valvoline in my transmission and was thinking about using it for the power steering. And I'm pretty sure my fluid is like a dark brown now.. I need to change it ASAP
Sponsored Links
Advertisement
Old 10-28-2018, 06:19 PM   #4
LeverThis
Valvoline is great, especially if it's on hand already. That's the Dex 6 valvoline? Brand isn't as important for power steering pump as for the transmission, as long as it's a Dex 3 or 6 atf. Many use Redline d4 atf as well.
Old 10-28-2018, 08:45 PM   #5
Chasepinkonsly
Yeah it's the Dex 6 Valvoline max life the same stuff I used in my transmission
Is power steering pump conditioner safe to use also?
Old 10-28-2018, 10:52 PM   #6
Dogthebountyhunter
My Ride: 03 M3 Vert 2005 745i
Lucas power steering stop leak works great as a conditioner. It looks like atf fluid too and really quiets the pump if it makes noise.
Dogthebountyhunter is offline   Reply With Quote
Old 10-29-2018, 07:29 AM   #7
markusmarkus
My Ride: 2018 M240i
The reason fir the confusion is that BMW used the same reservoir, made by ZF, in different series of its car’s. Some of those cars used the CHF11 fluid, while others, including the E46, uses Dexron3. The reservoir caps had different labels, with some labels stating that CHF11 fluid is required. The E46 uses Dexron3 or better.
Old 10-29-2018, 08:18 PM   #8
LeverThis
Originally Posted by markusmarkus View Post
The reason fir the confusion is that BMW used the same reservoir, made by ZF, in different series of its car's. Some of those cars used the CHF11 fluid, while others, including the E46, uses Dexron3. The reservoir caps had different labels, with some labels stating that CHF11 fluid is required. The E46 uses Dexron3 or better.
It's worse than just the erroneous fill caps on the replacement zf reservoirs, there have been a number of threads recently where BMW dealerships have recommended chf 11s to e46 owners. Even the op here mentioned an 'atf only' fill cap but was still asking about chf 11s.
Old 10-29-2018, 11:41 PM   #9
66intheSky
66intheSky's Avatar
My Ride: BMW
Year: 2000
Model: 328i ZSP
Transmission: Manual
Doesn't surprise me....my dealer has left numerous small parts missing from my car over the years. By the time I realize it, there's not much I can do but replace them myself. Sh1tty service to say the least.
Sent from my Samsung Galaxy J3 Eclipse using E46Fanatics mobile app
66intheSky is offline   Reply With Quote
Old 10-30-2018, 12:48 AM   #10
Antti
My Ride: 330CI / 316 1.8i
Year: 2005
Model: 330CI M-Sport II
Transmission: Automatic
In nordic cold countries we do have CHF 11S fluid which is yellow.
My 330ci is imported from Germany, and there is ATF logo in reservoir cap. So i have to use CHF for my sedan ja ATF for coupe.
So based on that i would say that bmw has been putting CHF fluids in cold climate cars.
Antti is offline   Reply With Quote
Old 10-30-2018, 01:17 AM   #11
My Ride: Lexus
Use ATF.
CHF was spec'd for E46s in cold climates.
Complete E46 Info • 5.7M VIEWS
Old 10-30-2018, 08:43 AM   #12
Fox Fader
My Ride: '05 325i
Whatever Dex you can get at Walmart under Supertec.
'05 325i handshaker CW Package 139k
M Shift Knob - 545i Short Throw w/ Blk Suede Boot - Tint: 20%r, 35%f - PowerStops
HomeLink® - Clear Fender Signals - LED Interior & Tag Lights - Tein S.Tech - Koni Str.t - Clear Corners - Yellow Fogs
10 Ford GT 401a 5sp 17k miles
17 Z125 PRO
07 Tuono Factory
03 F150 STX Lightning replica
Fox Fader is offline   Reply With Quote
