Friend fixing car, cant remember/find where this plugs into. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-27-2017, 03:59 PM   #1
328i46
My Ride: 99 BMW 328i
Any help? E46 328i
328i46 is offline   Reply With Quote
Old 08-27-2017, 05:03 PM   #2
All2kool
My Ride: 2002 325Ci
Given the location, I'd say that plugs into the Idle Control Valve. Not too many places it reaches too.
Previous:
All2kool is offline   Reply With Quote
Old 08-27-2017, 06:36 PM   #3
jmo69
My Ride: 03 325xi 98 328is
My guess is the disa valve
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is online now   Reply With Quote
Sponsored Links
Advertisement
Old 08-27-2017, 06:46 PM   #4
All2kool
My Ride: 2002 325Ci
If you look closely at the picture, you can see the DISA connector in the hole where the DISA should be. BMW engineers are fairly smart people - they only give enough slack for the connection to reach the intended connection and the plug in the picture is never going to reach the DISA.
Previous:
Old 08-27-2017, 06:54 PM   #5
shoman24v
My Ride: 2002 330i 2000 528iT
DISA connects at the DISA. That doesn't even reach it.
Everything plugs into something. You will figure it out.
| 2002 330i - SOLD | 2000 528iTA - 155k | 2017 X3 SDrive28i M Sport - 31k |
shoman24v is offline   Reply With Quote
Old 08-27-2017, 07:01 PM   #6
bobnagga
My Ride: 2000 323ci
This is why we ALWAYS tape and mark the connectors as we disconnect them. But, yeah. I just went and checked, and it's the ICV. It should be attached to the intake right above the throttle body inlet via a rubber grommet and a rubber... hold-down on a bare metal strip. Just below and forward of that gaping hole where your DISA used to be. It's recessed under the intake a little bit. Looks like an aluminum cylinder mounted horizontally, front-to-back. The small opening of the lower intake boot connects to it.
bobnagga is offline   Reply With Quote
Old 08-27-2017, 07:23 PM   #7
891CARLOS
My Ride: 2003 E46 325XI
See pic.
True Keyless Push Button System
Sports Steering Wheel
Eonon GA5150/Reverse Camera
HID projector retrofit + LED angel eyes
Smoked corners
Smoked LED Tails
Topspeedauto Catless Headers
Innovate LC1
Mtech ll Rear Bumper w/CF Diffuser
Vintage Gold 18" M3 Wheels
891CARLOS is offline   Reply With Quote
Old 08-31-2017, 01:07 AM   #8
powerstroke
My Ride: 330i G-string
Hai,wts function of the DISA valve?
powerstroke is offline   Reply With Quote
Old 08-31-2017, 01:21 AM   #9
bobnagga
My Ride: 2000 323ci
It passes butter.
Old 08-31-2017, 01:24 AM   #10
JeroenV
My Ride: E46 325Ti
Year: 2001
Transmission: Manual
The DISA valve changes the inlet trajectory in the manifold to be long or short. a longer inlet path gives more torque on lower RPM's and a short path gives more torque at higher RPM's. This way your car should have enough torque throughout the RPM range. As long as the DISA valve works
JeroenV is offline   Reply With Quote
Old 08-31-2017, 03:02 AM   #11
powerstroke
Oh ok,well explained,my car has been switching off by itself at low revs sometimes especialy wen engine is hot or after 2nd drive cycle.
Old 08-31-2017, 03:03 AM   #12
powerstroke
The only way it wont go off is wen I keep the aircon on,wt aircon off the revs rily get low,cn I suspect the DISA?
Old 08-31-2017, 08:31 AM   #13
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Start your own thread so you can get more eyes on it, instead of highjacking this one and derailing the convo.
Step 1) get OBD Fusion and wireless adaptor.
Step 2) read codes, freeze frame data, diagnostic report, fuel trims at warm idle and highway cruise speed, and post in your thread
Step 3) spell check your typing before posting
Old 09-01-2017, 05:12 AM   #14
jeng
My Ride: 2001 BMW 330ci
Idle Air Control Valve. I'm pretty sure the various plugs only go into the receiver they're supposed to plug into. Even if the IACV wire was long enough to reach the DISA plug (which it isn't), I don't think you'd be able to plug it in. The plug wouldn't fit.
jeng is offline   Reply With Quote
Old 09-01-2017, 09:23 AM   #15
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
There are a few connectors coming out of that octopus that can be plugged into the wrong connector, so label them and be mindful.
Old 09-01-2017, 09:54 AM   #16
powerstroke
Sorry for the highjack,just that I din't get enough help the last time I opened a thread for it,thanks for the info anyway.
