Replaced Alternator- battery light flickers and issues persist - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-11-2019, 09:21 AM   #21
beechbmw
My Ride: 2004 330ci Coupe
Transmission: 6 spd SSG
Originally Posted by cvx5832 View Post
Take it apart to look for corrosion. Or loose contact.
On corrosion, trust me there will be.
This picture shows a good place to check for corrosion. As may have been mentioned earlier, it is on the passenger side of the engine. Both ends of the cable should be taken loose and cleaned to shiny metal to ensure a good ground, even as just a preventative maintenance item if you are working in that area on something else:
https://www.google.com/imgres?imgurl...source=sh/x/im
Hope you find your culprit.
beechbmw is offline   Reply With Quote
Old 11-16-2019, 05:57 PM   #22
ghaiks
My Ride: E46 with 153k
Year: 2003
Model: 325i
I'm a little confused on the location of your referenced cable. Is this under the engine? I thought it would be in this area on the passenger side (photos attached)
Thanks for the help..
ID:	788271   Click image for larger version
ghaiks is offline   Reply With Quote
Old 11-16-2019, 06:09 PM   #23
jmo69
My Ride: 03 325xi 98 328is
Passenger side, underneath in the area near the motor mount. Look for a braided strap.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-16-2019, 08:06 PM   #24
beechbmw
The link in my post above shows a photo, as mentioned by jmo69, it's near the engine mount. Down towards the bottom of the engine. The picture in the link was likely taken looking down on the motor mount on an angle from the front.
Old 11-17-2019, 01:59 AM   #25
Archbid
My Ride: 330ci Convertible
Year: 03
Transmission: 5-Speed Manual
Agreed and emphasize!
Every document I've ever seen, or tested myself, about 12V systems is that a healthy alternator should be putting out at least 14V, plus a little more.
13.6+ is fine.
For the next person reading this:
1. Get a multimeter and learn how to test alternator output at the alternator. At the very least test at the posts by the drug bin while the car is on.
2. Unless there is a diagnosable issue with the alternator itself, buy a new voltage regulator. Super-easy to install, and saves $$$.
Archbid is offline   Reply With Quote
alternator, battery
