Rating: ![]() |
Display Modes |
#121 | |
#122 | |
#123 |
As far as whether the E46 325i uses pulse width modulation or not for the map thermostat...
Arguments in favor: 1. There is apparently a table of PWM values in the DME. 2. LED can't reliably tell whether the signal is DC 12 volt or PWM. Arguments against: 1. Other forum posts show that SOME BMW's use PWM, and other BMWs use DC 12 volt. 2. The DURATION of the 12V DC signal (say 2 seconds, 3 seconds, 4 seconds, etc) clearly correlates with how much the ECT temperature drops, so I am not sure that the DME needs the additional use of PWM to control the MAP thermostat. but most importantly: 3. My own experiments have consistently shown that even when the LED light goes on for a few seconds, the PWM percentage number (obtained by a OBD2 app such as Carly ) NEVER showed any blip or change. Definitive proof would be if I connect an oscilloscope or a similar device to the MAP 12V line. I may get around to doing that one of these days. Circumstantial evidence makes me question whether there is any PWM at all to the MAP thermostat in my E46 325i. Last edited by emineid; 11-10-2019 at 07:16 PM. |
Sponsored Links | ||
Advertisement | ||
#124 | ||
The electric fan has a fan controller for two reasons. 1) The fan would draw far more current than the DME can provide, so it cannot drive the fan directly. 2) Motors tend not to do well with direct PWM signals, so the fan controller will receive a duty cycle from the DME and use that to generate a varied voltage. Furthermore iirc the fan controller uses an inverted signal and treats values of 0% and 100% as error states (shorts to ground or 12v)
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#125 |
It just occurred to me that the 12v signal to the MAP thermostat *is* DC 12 volt, and that it also *is* pulse width modulated.
In this case, the signal appears to be DC 12 volts during the 2 to 5 seconds (or thereabouts ) that it is on, to heat the wax. But the "width" of the signal is modulated. Meaning, the duration of the signal varies depending on the target coolant temperature. In this case, the width is not in milliseconds, but is in the 2 to 5 second (approx.) range. So it isn't ________-_-_-_-_-_-_-__________ But is ________----------------__________ I am curious so I will probably eventually hook up an oscilloscope to the signal, but this is what may be happening. Last edited by emineid; 11-11-2019 at 07:51 AM. |
Display Modes | Rate This Thread |
